V 240.x: Render Elements issue: Only 1 MultiMatte saved
  • V 240.x: Render Elements issue: Only 1 MultiMatte saved
    Hi all
    I have this problem _ I use more than 1 MultiMatte render elements and the Frame buffer - upon rendering only saves 1
    I do see all of them in the dropdown list but after the render process ends - only one gets saved. (names are distinct - I made sure)
    The one that is saved ignores the name I gave it under the render elemenmts UI
    Same goes if I try to save the channels manually from the VFB UI (the multi floppy icon)
    EDIT: SOLVED - I had to rename the elements in NAME and not only where the full path is (which is unintuitive since there are 2 places where one can change the output file name)
    regards
    NIR
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    Originally posted by nirsul View Post
    Hi all
    NIR
    Yes, this the only solution for the moment, we will try to improve this a little bit.
    Tashko Zashev | chaos.com
