Distributed rendering failed due to lightcache loading error
  • Distributed rendering failed due to lightcache loading error
    I'm facing a lot of trouble to get DR working with BF/LC on vray 2.4/max 2014.
    The LC is done on the main computer, then save to a share folder (read/write/full permission).
    All server are giving the following message: Aborting render: failed to load light cache "\\CORETO\maps\RenderFarmTest\lc.vrlmap"
    BF/BF work fine
    Using Backburner work fine for now under the same configuration.
    Thanks to let me know how to solve the problem.
    UP....
    I have been trying to solve the issues without success so far.
    Originally posted by fraggle View Post
    BF/BF work fine
      When using BackBurner are you using Distributed Rendering as well?
      Is the issue only Light Cache related - what about textures,proxies,Irradiance Map caches and all other assets in the scene?
      How did you start VraySpawner on the render servers, manually or as a windows service?
      Is the issue scene-dependent or it persists in every scene?
        Test with BB is done without DR.
        Vrayspawer is started as a window service
        The scene is a basic scene test, here attached.
        Same occur to any scene.
        All combination give the same error : LC/BF - BF/LC - IR/LC
        The slave are running under Windows Serveur 2008 R2.
          I reverted from Vray 3 to 2.4 on the main workstation.
          I notice that the vray toolbar remain on the UI without any icon.
          Could it be part of the problem?
ID:	852021It as been solve by doing the following:
            See picture attached.
              That is what I had in mind when I asked you about how VraySpanwer has been started.
              Glad to hear you solved it out.
