VRay Stereoscopic Elements Broken
  • VRay Stereoscopic Elements Broken
    VRay Elements are not rendering properly for when a VRayStereoscopic helper is active.
    All Render Elements are only writing a single eye while the beauty pass is both!
    Will try previous builds since there is a rather urgent need to start rendering.
    VRay 3.00.06
    Max 2014
    -Joel E
    https://www.biglittlepictures.com
    Thanks for the pointer; will check it out as soon as possible.
      More details. After a test, the conclusion is not the helper itself, but the adjust resolution checkbox on the helper. This does not get compensated for within render elements. The work around will have to be setting the resolution manually, and then unchecking this box.
      -Joel E
        Are you saving through Render Setup / V-Ray / Frame buffer / V-Ray raw image file or from the Common tab ?
        If you are saving through the max's render output, try disabling the VFB and add all render elements manually when choosing the .exr format in Render Setup / Common / Render Output / "Files ..." button.
        Peter Matanov
        Chaos
          Ahh I saw your post after I posted .. Try saving through VFB / V-Ray raw image file and Adjust resolution ON, it should be fine (don't forget to disable render output in Common tab).
          Peter Matanov
          Chaos
