Vray Hair Prim with Hair & Fur in Max 2014 - Minimum Thickness Limit?
  • Vray Hair Prim with Hair & Fur in Max 2014 - Minimum Thickness Limit?
    There appears to be a bug in Vray 2.4 when rendering Max Hair & Fur as Vray Hair Primitives in Max 2014 that prevents the strands from going below a width of around 0.125 units. I've tested the same thing using Hair Farm and it works ok, plus rendering the Hair & Fur as MrPrims in Mental Ray works correctly as well. Is there any solution to this problem without upgrading to Vray 3.0 (assuming it is fixed there) or changing to another hair plugin?
    Thanks,
    Mitch
    Hm, I think we fixed this a long time ago. Have you checked out the 2.x nightlies?
      I have not. We usually shy away from non-release builds here at work. I will test at home.
      Thanks,
      Mitch
