Vray 3 VrayFastSSS2 dark outlines around object edges
  • Vray 3 VrayFastSSS2 dark outlines around object edges
    i have a snow scene where i got two objects that are vertex-tight next to each other, but not attached together (can not do that due to the point cache) and when i use VrayFastSSS2 snow material, i get dark outlines around the area where the objects join. I am using simple mode. Raytraced mode is not an option as it takes ages to render.
    Any help would be really appreciated.
    EDIT: Raytraced mode does it as well
    EDIT2: Setting multiple scattering to anything else than raytraced solves the problem, although i am not sure if it would flicker in animation....
      Would it be possible to send us your scene file to support@chaosgroup.com ?
      It seems to be similar issue as the one we have discussed on this thread:
      http://forums.chaosgroup.com/showthr...ring+raytraced
      Thank you.
      Tashko Zashev | chaos.com
        Originally posted by tashko.zashev View Post
        Thank you.
        Yeah, i can, but it will take some time. I am already screwed, as other solutions flicker as hell and i missed deadline due to this. :/
          Did you find a solution to this?
          We appear to be having the same issue here.
          Patrick Macdonald
          Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
            We did some changes for the next service pack in order to prevent such SSS render artifacts in Multiple scattering - Raytraced mode.
