Hey guys, I am having some problems getting our render nodes to pick up the licence info from the workstations. Here's the log from one of the nodes;
It's odd because I am able to ping all machines just fine, and the license info hasn't changed since updating from 2.4. Any ideas?
[2014/Jun/2|13:06:14] ================================================== ==========
[2014/Jun/2|13:06:14] Console created, V-Ray A for x64 from Apr 8 2014, 01:09:10
[2014/Jun/2|13:06:14] Compiled with Intel C++ compiler, version 12.1
[2014/Jun/2|13:06:14] Host is 3dsmax, version 16
[2014/Jun/2|13:06:14] V-Ray DLL version is 3.00.02
[2014/Jun/2|13:06:34] Broadcasting TM_SERVER_STARTED after start up
[2014/Jun/2|13:06:34] Received TM_START_RENDER from 10.0.0.139
[2014/Jun/2|13:06:34] Starting DR session from 10.0.0.139
[2014/Jun/2|13:06:34] Receiving DR scene from 10.0.0.139
[2014/Jun/2|13:07:07] [VRender] Constructor entered (loading from file).
[2014/Jun/2|13:07:07] Setting default filter kernel.
[2014/Jun/2|13:07:07] [VRender] Constructor done.
[2014/Jun/2|13:07:07] Loading from file.
[2014/Jun/2|13:07:07] Loading filter parameters.
[2014/Jun/2|13:07:07] Adding host "10.0.0.217":20204 from scene
[2014/Jun/2|13:07:07] Adding host "10.0.0.236":20204 from scene
[2014/Jun/2|13:07:07] Loading done.
[2014/Jun/2|13:07:07] [VRender] Constructor entered.
[2014/Jun/2|13:07:07] VRenderer destructor entered.
[2014/Jun/2|13:07:07] VRenderer destructor done.
[2014/Jun/2|13:07:10] Scene loaded from "C:\Users\Render\AppData\Local\Autodesk\3dsMaxDesi gn\2014 - 64bit\ENU\temp\vray_server_scene.max"
[2014/Jun/2|13:07:10] [DR] getting sequence data...
[2014/Jun/2|13:07:11] Extracting sequence data from RendParams.
[2014/Jun/2|13:07:11] Setting up V-Ray parameters for frame rendering.
[2014/Jun/2|13:07:11] Extracting sequence data from VRender.
[2014/Jun/2|13:07:11] Forcing multithreading
[2014/Jun/2|13:07:11] A render elements manager with 2 elements detected
[2014/Jun/2|13:07:11] Render element: VRayGlobalIllumination
[2014/Jun/2|13:07:11] Render element: VRayRawReflection
[2014/Jun/2|13:07:11] [DR] Calling beginSeqeunce()
[2014/Jun/2|13:07:11] Current project folder is "C:\Users\vlado\Documents\3dsMax"
[2014/Jun/2|13:07:11] Checking for missing files.
[2014/Jun/2|13:07:11] Entering beginSequence().
[2014/Jun/2|13:07:11] Setting RenderGlobalContext.
[2014/Jun/2|13:07:11] Broadcasting NOTIFY_PRE_RENDER.
[2014/Jun/2|13:07:11] Tiled bitmap cache size set to 1000 MB
[2014/Jun/2|13:07:11] Preparing renderer...
[2014/Jun/2|13:12:48] error: Could not obtain a license (10060).
[2014/Jun/2|13:12:48] Calling renderBegin().
[2014/Jun/2|13:12:48] Sending RenderBegin().
[2014/Jun/2|13:12:48] Caching camera animation.
[2014/Jun/2|13:12:48] beginSequence() done.
[2014/Jun/2|13:12:48] [DR] Calling endSeqeunce()
[2014/Jun/2|13:12:48] Entering endSequence().
[2014/Jun/2|13:12:48] Calling renderEnd().
[2014/Jun/2|13:12:48] Calling renderEnd() on render materials.
[2014/Jun/2|13:12:48] Unloading bitmaps.
[2014/Jun/2|13:12:48] Freeing render instances and lights.
[2014/Jun/2|13:12:48] Sending RenderEnd().
[2014/Jun/2|13:12:48] Sending RenderEnd() to atmospheric effects.
[2014/Jun/2|13:12:48] Sending RenderEnd() to render effects.
[2014/Jun/2|13:12:48] Sending RenderEnd() to the tone operator.
[2014/Jun/2|13:12:48] Sending RenderEnd() to environment maps.
[2014/Jun/2|13:12:48] Sending RenderEnd() to override mtl.
[2014/Jun/2|13:12:48] Broadcasting NOTIFY_POST_RENDER.
[2014/Jun/2|13:12:48] endSequence() finished.
[2014/Jun/2|13:12:48] Closing DR session from 10.0.0.139
[2014/Jun/2|13:12:48] warning: Failed to delete server scene file "C:\Users\Render\AppData\Local\Autodesk\3dsMaxDesi gn\2014 - 64bit\ENU\temp\vray_server_scene.max" (0)
