Okay. I still got crashes with standard material after a bit.
I recalled something said about LC showcalc causing issues with something (probably unrelated). I've not disabled show calc for LC and I haven't had one crash in about 15 mins...
same here, had a lot of crashes with vector maps, but really inconsistent so i've not been able to narrow down the problem. some maps work fine, while others crash every now and then. makes me think there is something specific with certain maps that messes up.
Yes I was thinking the same thing about the map. Maybe I should try and save in a different type of vector format.
Anyway, I decided to switch to standard max renderer and render using that. Even though the max render was a lot better with the map I still got a couple of crashes which leads me to the conclusion that it is either a buggy feature or there is indeed something slightly amiss with the map.
