Reflect alpha doesn't work with vray 3.00.07
  • Reflect alpha doesn't work with vray 3.00.07
    I have a problem with the vray version 3.00.07 for 3dsmax 2015 64bits
    when I check the matte object affect alpha and alpha contribution -1.0 in vray propertie option of my object the apha reflection is black but with the version 2.40.03 i see the alpha reflection of the object.
    Is that something has changed?
    thanks for your answer
    We are working to fix this for the 3.x builds. As soon as we have any update will post here.
    Tashko Zashev | chaos.com
      Is there any fix for this in the nightlies builds?...This have become a severe problem in our organization and going back to Vray 2 to is going to cause problems since our pipeline is now standardized on Vray 3
      Please have a fix for this ASAP!
      Thank you!
      "I have not failed. I've just found 10,000 ways that won't work."
      Thomas A. Edison
        It is not fixed yet - we are working on that regard.
          This issue will be fixed for the upcoming Stable nightly 3.x build.
            is this in the nightly builds yet?
            Thomas A. Edison
              Just tested the latest stable nightly build...it still broken...it kind of works but there some issues using a VrayMtlWrapper for Matte shadow and reflection with fresnel reflections.
              *Update*
              Seems to be broken without fresnel reflections too...Just random results when adjusting the reflection and diffuse color for the floor.
              Thomas A. Edison
                The fix is not in the stable builds yet. Will merge it today so that it can be included tomorrow.
                  yet Multi/SubObject Mtl
                  Reflection of MatteObject will be ignored if Reflection Mtl is included in Multi/SubObject Mtl.
                  test scene
                  oak2012.zip
                  OakCorp Japan - Yuji Yamauchi
                  oakcorp.net
                  v-ray.jp
                    test scene
                    [ATTACH]20178[/ATTACH]
                    Thanks for the feedback - we'll add this bug into our system and let you know when we have it fixed.
                      Hi Vlado,
                      Unfortunately there is something still broken with the latest stable build...The LC calculation and rendering time goes through the roof!. I have sent a scene to support...I have a VrayMtlWrapper for Matte shadow and reflection on the V-ray floor plane.
                      **update**
                      Seems to be related to using the V-ray floor plane
                      Ticket number #173656.
                      Thomas A. Edison
                        I can't see the scene in the ticket right now - will get it tomorrow from the support guys and will let you know how it goes.
                          Thanks for the scene; this is fixed for the next nightly/stable tomorrow.
                            Now I think catch shadow is not working...I cant only catch shadow now.
                            Thomas A. Edison
                            • #15
                              Would it be possible to attach a simple scene for this issue and the exact V-Ray build that you are using ?
