Problem with DR and LightCache
  • Problem with DR and LightCache
    When I'm with the DR option, the lightcache not appear previewed. How can I fix this?
    Generally the Light cache preview should work with or without DR. Which V-ray and 3ds Max version is this ?
    Assuming that ' Show calc phase' is checked.
    Is it scene dependent? If yes please send us the file to run a test.
    Thank you.
    Tashko Zashev | chaos.com
      Go to GI settings>Light cache>enable Show calc phase.
        Hi all.
        That option is on.
        I send the files soon
        Thx all
          Originally posted by AndresAhumada View Post
          Hi all.
          That option is on.
          Thx all
          Looking forward for the scene file (support@chaosgroup.com)
          Please don't forget to add this thread as a note. Thanks.
            I sent the email whit link for download.
            Cheers
              Thank you, we have replied to your mail.
                Hi tashko... need your help.
                In the same scene to send you the last time, has emerged a big issue I do not understand.
                When rendering the frames 449, 516, 630, 631, 632, 710, 712 max crashes.
                You Might help me and see what problem?
                Greetings.
                  We'll see if we can render these frames into our environment and we will update you afterwards.
                  Meanwhile you could inform us which Vray/3DSMax version you are using on your side.
                    3d max design 2014..... windos 8.1
                    64 giga ram
                    And tomorrow we have delivered with the customer ... It could not happen at a worse time
                      And what is the exact Vray-version?
                        for max 2014
