3ds max very slow to recover after rendering?
  • 3ds max very slow to recover after rendering?
    I'm not sure this is a VRay issue or not.
    On some scenes it happens that after rendering (especially when rendeirng particles) max takes its time to recover. Even if the rendeirng takes like 2 seconds, I will have to wait at least 15-30 seconds until max responds again.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    Which max and vray version is this?
    There was an issue a while back with Nitrous, and in viewport properties if you just untick "Improve Quality Progressively" under Display Performance, it helped a LOT. But as I say that was a while back, can't remember the max and vray versions now
    Kind Regards,
    Morne
      Max 2014 and VRay 3.0. I will try that. Thanks
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
        It could also be the renders you are saving. If they are very big and you have many layers they will take their time to release max...
          I don't save them at the moment, neither in the History nor on disk. I tried the Nitrous thing and it doesn't make a (notable) difference.
          Software:
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
            Are you rendering from a "shaded" viewport?
            If so go back to wireframe before you render and you will notice a massive difference
            Chris Jackson
            Shiftmedia
            www.shiftmedia.sydney
              That actually seems to help! I'm not sure of the time factor it gets faster since my scene got heavy stuff also, but Thanks!
              Software:
              3ds Max 2016 SP4
              V-Ray Adv 3.60.04
              Hardware:
              64GB RAM
              DxDiag
                I had a similar-sounding problem that seems to have to do with Nitrous re-initializing materials and maps after a render.
                Save your scene, then try switching to 'Shaded materials without maps' in the viewport shading menu. Totally fixed the problem for me, but if you switch back to 'Realistic materials with maps' it'll enable the display of every map in your scene no matter how it was set up previously, hence saving your scene first and proceeding with caution. Max might hang for a while as the materials/maps get swapped.
                Hope this helps,
                Dave Stewart
                TEAGUE
                  I had a similar issue using Embree with static geometry when my RAM amount was too high. When I left 3.2 GB or so for the OS, the problem seemed better.
                    Hi, thanks for your reply. My system has 64 GB of RAM and the rendering doesn't get over 20GB (My dynamic memory limit it set at somewhere around 55 GB)
                    Software:
                    3ds Max 2016 SP4
                    V-Ray Adv 3.60.04
                    Hardware:
                    64GB RAM
                    DxDiag
                      Originally posted by Art48 View Post
                      Would it be possible to send us a sample scene and inform us in advance how much time it takes until Max becomes responsive after the render ends?
                      What is the exact Vray 3.xx.xx version?
                        Will do. The next time it happens I'll remember the time and send it to you. Propably within the next few weeks.
                        Software:
                        3ds Max 2016 SP4
                        V-Ray Adv 3.60.04
                        Hardware:
                        64GB RAM
                        DxDiag
