Strange title. Basically I just installed a second workstation with another VRay Workstation license and proceeded to use said machine as master and another workstation as slave for DR.
After some hassle regardgin refused connections I got it to work after a restart; BOth machines render. The only problem is, that the slave machine doesnt find ANY assets when used as DR slave. When I render locally on the slave machine everything works fine, no errors, access to all assets on a network drive.
Now this is not a gamebreaker since the "Transfer missing assets" function does its job very well (thanks for that option!) but I would like to know nonetheless why the slave cant find any assets despite having the same exact network structure, drive letters etc, all identical, and it works locally on the slave.
EDIT:
Just tried it vice-versa, slave machine being the master, and former master being the slave, doesnt work either, same issue. master renders fine, slave doesn't.
VRay 3.00.07
3ds Max Design 2014
UAC off on both machines
EDIT:
VRay 3.00.07
3ds Max Design 2014
