VrayColorToBump doesn't allow maxscript access
  • VrayColorToBump doesn't allow maxscript access
    Hey there. So I have a function that will take any max material and return all submaps associated with that material. See below...
    fn sLibGetMapsFromMaxWrapperObject inputMat a =
    matsToProcess = #(inputMat)
    for mat in matsToProcess do
    if mat.numsubs != 0 then
    for i = 1 to mat.numsubs do
    if mat[i] != undefined then
    if classof mat[i] == SubAnim then
    if superclassof mat[i].object == textureMap then
    if mat[i].object != undefined then append a mat[i].object
    append matsToProcess mat[i]
    But now say I have a material, and I place a VrayColorToBump in the bump slot, and then place a noise in the map, when I run my script, I get only the VrayColorToBump map in return, not the submap as well. My function seems to work with all maps types except this one vray one. Does VrayColorToBump have full maxscript acess? or am I doing something wrong. Thanks for any help!
    - Neil
    Thanks for the pointer; will fix it.
      thanks Vlado!
      - Neil
        Any update on this? Thanks for any info.
        - Neil
          - Neil
          I think it is not fixed yet, but let me check again the status of this case.
          Tashko Zashev | chaos.com
            Thanks Tashko!
            - Neil
              Any new update on this? I've written a script to mass assign a node to all VrayTriPlanarTex maps, but it skips all tex maps inside of a vrayColorToBump since there's no maxscript access to its map slot. Help!
              - Neil
                This works fine for me - created a VRayMtl material with VRayColor2Bump in the bump slot and Noise texture in it. Running your script correctly returns both the VRayColor2Bump texture and the Noise texture. Should I be using some other way to reproduce the issue?
                  Mine still fails. Could it be a version issue? I'm using max 2016 SP1 and Vray 3.20.03.
                  - Neil
                    Yes, the fix is not available in 3.20.03, it will be available in the next service pack.
                      Awesome, thanks!
                      - Neil
                        Fixed in 3.3. Thanks!
                        - Neil
