I am trying to animate some boxes with maxscript. I've setup callbacks to watch for a dummy's transformation change, a TimeCallback, and i've tried to setup a #preRenderFrame callback.
So far so good as far as max goes. I can move the dummy and the boxes will change. I can also animate the dummy and play the animation, the boxes will update. It took a minute to figure out how to have it update at render time but eventually that worked too.
Now i'm having issues with vray.
The sequence renders fine for a while, and then starts spitting out really odd frames:
rgb
diffuse
raw gi
If i just render that frame out of the sequence, it renders normal.
The second issue, i tried rendering with vray RT as a previewer, it crashes after about 10 frames every time.
rgb
diffuse
raw gi
