I'm rendering an image with multiple light passes. I wanted to use a mix of Vray Adv and Vray RT.
Alas the FOV does not match. I'm using the Vray physical camera with type "default" set in the render settings. The RT image has a slightly wider FOV than the Adv image.
Should I simply use the standard max camera with the Vray exposure control. I'm doing all my lens FX in post so is the and advantage in using the VRay physical camera ?
