Licensing Emergency - Can't get license to work over network for render node
  • Licensing Emergency - Can't get license to work over network for render node
    Hi Chaos folks,
    I've just installed a fresh win8.1, max design 2014 sp5 and vray 3.00.07 on one of my nodes with network slave installation. I can't change the license server name or port - vrlservice.xml appears to be locked somehow. It's not set to Read Only. I am an admin user.
    I've tried changing the settings through vray UI, through the dedicated license management app and manually direct in the file but no luck.
    I am not running the VRayspawner service or manual app either, although when I try to register the vray spawner service nothing happens at all, it seems.
    Any ideas for how to address this asap?
    Many thanks!
    Alex York
    Founder of Atelier York - Bespoke Architectural Visualisation
    www.atelieryork.co.uk
    When I try to use the "change vray license server settings" app i get "cannot save settings".
    I think somehow the license files are locked but I can't see how. The files and folder are not "Read Only".
    Alex York
      Even though you are logged in as admin, please use Run as administrator option to change V-Ray client license settings.
      You can do that by right clicking on "change V-Ray client license settings" and choose "Run as administrator"
      Let me know if this helps you.
      Tashko Zashev | chaos.com
        I've just remembered that you need to do a Custom Installation and set the server there before you install 3.x. Fingers crossed this solves it!
        Alex York
          Thanks Tashko - re-installing with the server set up before installation has sorted it out I think.
          I will remember the need for running as Admin as well.
          Thanks,
          Alex York
            Good news, thank you for sharing your solution.
              No problem - all up and running now.
              And for the record good LORD is windows 8.1 terrible.... sorry had to get that off my chest!
              Alex York
