I have this problem once in a while since a long time. When I comp render elements from vray and I use effects like reel smart motion blur, glow and depth of field I get strange white artifacts and sometimes entire white frame just on a few frames.
My project is in 32 bits linear sRGB. The rendered frames are 16 bit float EXR. Everything is separated in vray render elements with the raw and filter parts.
I was always able to get rid of these in the end by tweaking the levels of the culprit layer. In the case below it was the reflection layer of the red bowl (vrayRawReflection and vrayReflectionFilter) causing artifacts with the subsequent depth of field (lenscare). But I would like to know if someone found a way to avoid them. Maybe in another compositing app like nuke or something...
