I have just used the "Perspective Matching Tool" in max 2014 to create a perspective matched standard Camera.
The actual quality of the match is pretty good.
If I try and use a Vray Camera to match the same image, the x/y/z (or just xy) alignment tools just spin out of control and the camera flips, and I basically lose control of the camera.
If I use a standard max Camera and then load a Vray camera into the scene, select the camera port, press P and then "ctrl-c" in that port, the vray camera gets translated, but the perspective is completely off.
If I change the Max camera to a targeted camera and then adjust the focus distance, again the viewport looks "wrong" and the illusion is destroyed.
So what has happened to the max camera, why is behaving in this strange fashion, can I convert it to a Vray camera. And why is the focal length way different to the EXIF data that I have from the .CR2 that I shot?
Raj
Raj
