Vray 2 Distributed Rendering Problem
  • Vray 2 Distributed Rendering Problem
    Hello,
    I'm having trouble getting DR to work, some times it works, other times it doesn't. I have 1 workstation, and 1 node, connected via a switch.
    Also the scene doesn't appear to make any difference.
    I have played around with the DR settings, names, etc, and nothing appears to make any difference, and it appears like a total lottery wether the node connects or not.
    I've also deleted the vray_dr.cfg file, so that's all reset.
    Any suggestions / solutions please send my way!!
    Thanks,
    Dean
    Does anyone have any suggestions, this is starting to really annoy me?
    Thanks,
    Dean
      Are the IPs unique ?
      Is the node or server using the same IP ?
      3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
        Please make sure that the Restart Servers on Render End option from DR settings is activated.
        This could be also a network issue - try to ping the machine when this errors appears again.
