3ds Max 2015 Crash when calculating light cache
  • 3ds Max 2015 Crash when calculating light cache
    Hey,
    I have a serious problem with certain scenes.
    Everytime I want to render, the light cache starts calculating, stops after about half a second, freezes for a moment and the max crashes with no visible reason.
    I have 3ds Max 2015 SP2 and V-Ray 2.50.01 installed.
    When I save the file as Max2013, reopen it, it works for exactly one rendering. When I want to render it a second time or another frame, it crashes again - even without saving or changing anything.
    It also happens when I send the scene out for network rendering with backburner.
    Any suggestions, why this might be happening?
    No, I'm not sure right away - can you send us the scene to support@chaosgroup.com so that we can investigate?
      Unfortunately, 3ds max stop working and I have to kill it manually
      AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
      2D | 3D | web | video
      jiri.matys@gmail.com
      https://gumroad.com/jirimatys
      https://www.artstation.com/jiri_matys
      https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
      https://www.instagram.com/jiri.matys_cgi/
      https://www.behance.net/Jiri_Matys
      https://cz.linkedin.com/in/jiří-matys-195a41a0
        I just need the scene... or this happens on any scene?
          I don't know that problem of Jiri Matys, but concerning my initial problem:
          I guess I cannot send you the scene right now because it contains sensitive data from a customer.
          I don't think I can reproduce that error without those models, because except of them there is only a vrayplane and a dome light in the scene... :/
            Ok; after the crash, do you get the 3ds Max CER dialog?
              Usually I got one, but when I wanted to reproduce it just now, it gives me another error indicating, that the f-edge plugin causes the error.
              Maybe because I use imported CAD-data there is a problem with open edges.
              I am pretty sure, that the other scene I had that error in, was with no f-edge but with vray edges tex.
              But maybe it was also because of open edges in the cad-data, that often causes any problems.
              I will have an eye on this and will come back, if the error is of another cause.
              Nevertheless, thank you so far
                Hi
                don't know if this is related or is helpful - I also had a scene recently where the light cache would start and then crash Max completely. This was in Max Design 2014 (Vray 3.00.07). The problem started when I did a boolean operation on some imported Revit geometry. When I converted the geometry to poly everything was cool again
                  Originally posted by Bruce Hart View Post
                  Hi
                  If you could send us a reproducible scene file, it will be very helpful. We will try to find what cause this issue.
                  Tashko Zashev | chaos.com
                    Hi again.
                    Attached is the offending bit of geometry in the scene. It will render in scanline and Mental Ray, but will crash Vray. Mental Ray complains about bad face normals, but it will render it. As you will see in the file there is a Pro-boolean applied which is causing the problem.
                    This is a Max Design 2014 file
                      Thank you for the scene file, the issue was reproduced and added to our bug tracker.
                      When we have a fix for it, we will update the topic.
                        Hi Bruce,
                        We have fixed the crash with this type of geometry, but warnings will be printed to the V-Ray log for invalid normals.
                        The polygons that have wrong normals will be rendered. However, the fix is in the nightly builds only.
                          Great Tashko - thanks very much!
