"Volume light" broken in Vray 3.0?
  • "Volume light" broken in Vray 3.0?
    Hi there,
    I just had a scene where I needed to make some "god rays". Usually I just put a black override material in the override slot, make a max standard light, set shadows to "shadow map" and add a Volume Light in the "Atmospheres&Effects" tab of the light and I´m done.
    But now all i get is an "Unhandled Exception" when I hit render...
    Did you change something here or is my scene broken somehow?
    Edit: Yep. Seems something in my scene won´t play along. Just opened an old scene and it works fine there...so off to troubleshooting my stupid scene...yay...
    If you post the file I could check it as well. Maybe we can fix this crash if it is V-ray related.
    Tashko Zashev | chaos.com
      Thanks, but I already pinned it down to the particle flow in the scene...now I just gotta figure out whats wrong with it...
        Let us know if you find a solution about it.
        If you can't please pack the scene and send it for investigation.
