Why saved images do not look the same as in VFB ?
  • Why saved images do not look the same as in VFB ?
    How do I ensure that my saved PNG image file from the VFB will look the same as when I bring it into Photoshop ?
    The image always comes into PS lacking contrast and flat.
    I have sRGB turned on, I save with and without Gamma 2.2 or 1.0 (whichever looks closest).
    It's as though the Correction Curves I apply in VFB or the Color Mapping isn't baked into the image.
    Any suggestions ?
    Many thanks.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    disable sRGB and it will look the same or go to gamma settings and from that drop down make it 1 on top and type in gama at 2.2.
      Thanks Darius,
      But it's not that.
      It's like I play with my Curves and exposure adjustments etc in VFB, then I save the image, and no matter what setting I put into the Gamma, it will come out less contrast in Photoshop. (when I have chosen the right way to go with gamma).
      Often I work in LWF, but sometimes I go Exponential, or Reinhard.
      Jez
        How you save the file? If you want to keep vbr settings I think u need to save from VBR itself not let max autosave it.
        On top of that vbr adjustment settings are just quick previews, u should really do the grading in ps/other software.
          I've worked it out.....of course.... VFB works in 32bit..... saving to EXR will retain the look from VFB.....
          Thanks for your help Darius, questioning how I saved (to PNG) which of course is only 16bit....
          Jez
