Render to Texture -> Multimatte Element, Specular & Light Select ?
  • Render to Texture -> Multimatte Element, Specular & Light Select ?
    Hi guys,
    I'm converting a scene from a job I'm working on from Vray to reel time engine and I need to apply the same color correction on the backed textures as in the final renders.
    I can't find any of the Multimatte elements, the light select, nor the spec elements in the Render to texture elements dialogue box.
    All the other that I need are there : GI, Lighting etc
    Would appreciate to have any help on this one,
    Cheers
    Stan
    3LP Team
    That doesn't sound like fun...
    I'd try and make as many adjustments back into the scene that I could before working on the baking. And/or break up the objects that need special adjustments so you can make the tweaks per texture baked, instead of needing multimattes?
    Brendan Coyle | www.brendancoyle.com
