Shimmering or buzzing effect removal?
  • Shimmering or buzzing effect removal?
    Hello and thanks for your time,
    I rendered a very reflective object with many fine lines running along it that are close to each other. In a high res image, they look good and distinct but when you make the image smaller or print it as a small frame, the lines get compressed and there is a buzzing or even a "morré" pattern.
    What are good rendering parameters to remove this effect completely?
    My rendering was: 3000 x 3000,
    adaptive DMC (apaptive noise at 0.005 and noise threshold at 0.01),
    Antialiasing on with Mitchell-Net (Blur 0.4 and Ringing 0.3),
    Sampling at 1/6
    Please help, thanks. K
    you might want to avoid sharpening filter, use area or quadratic to remove moire. For fine lines you need higher min sampling in dmc sampler. Something like 3/16 should do the trick.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      thank you sir, I'll try that out again!
