Bitmaps Black using VrayHDRIMap loader and Vray 3.1
  • Bitmaps Black using VrayHDRIMap loader and Vray 3.1
    So I loaded an old file (that rendered fine in vray 3) and tried rendering it with Vray 3.1, the bitmaps (loaded with VrayHDRI Map loaders) all rendered black.
    If I remake the VrayHDRI Map loader and load the exact same bitmap, the texture is now correct. Any idea what may be going on and how to fix this? Thanks.
    - Neil
    Ok, seems to be working now. I had seen that there was a bad build, I was sure I had downloaded the build AFTER it had been fixed, but maybe the build in my download area took a bit to update. Redownload and reinstall seems to be working now. Thanks!
    - Neil
      Ok then, let me know if there is anything else.
