Embry causing crash on Vray 3.10.02 render
  • Embry causing crash on Vray 3.10.02 render
    I am crashing when Embree is on in build V-Ray/Max - 3.15 12/18 nightly Max 2015 SP3
    Ironically, i am not using GI at all and the error returned is listed below. No biggie, turning embree off is easy.
    [2014/Dec/19|12:04:44] Rendering frame region (0,0)-(4000,2250).
    [2014/Dec/19|12:04:44] Photon size is 56 bytes.
    [2014/Dec/19|12:04:44] Light cache sample size is 120 bytes.
    [2014/Dec/19|12:04:44] Rendering image.
    [2014/Dec/19|12:04:44] Setting up 32 thread(s)
    [2014/Dec/19|12:04:44] error: UNHANDLED EXCEPTION: Rendering region (896,0)-(928,16)
    Last marker is at ./src/globillummap.cpp, line 1694: GlobalIllumMap::buildLightMap() {1}
    -Joel E
    https://www.biglittlepictures.com
    It would be great if you can send me the scene to vlado@chaosgroup.com so that I can look into it and fix it.
      I have exactly the same problem.
      [2015/Jan/11|08:26:01] Setting up 12 thread(s)
      [2015/Jan/11|08:27:43] error: UNHANDLED EXCEPTION: Rendering region (2816,236-(2848,2400)
      Last marker is at ./src/globillummap.cpp, line 1903: GlobalIllumMap::buildLightMap() {5}
      Also when embree is on the warning message return an invalid bump normal appears.
      When embree is off - everything is fine.
      This is a signature.
        I can only repeat what I said above. I can't really tell anything without a scene.
          Just curious what updated info there might be on this. I turned off Embree and the error didn't go away. I am, although, using a precalculated irradiance map.
          [V-Ray] UNHANDLED EXCEPTION: Rendering region (1744,944)-(1760,960) Last marker is at ./src/globillummap.cpp, line 1694: GlobalIllumMap::buildLightMap() {1}
            Is there any change to send us the scene for investigation?
            What is the exact V-Ray and 3DSMax versions that you are using?
