Render Last in VFB - problem.
  • Render Last in VFB - problem.
    Hi all.
    After a few renders in all my scenes, when I click the render last button in VFB, this button not works and the only button to make render is the Render and Render last 3ds Max native, not the V-Ray VFB... I don't know the reason.
    Any solution?
    Thanks.
    Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
    Spanish V-Ray 3.0 Licensed Instructor
    Artefaktos 3D&FX School
    @artefaktos3d
    Which 3ds Max and V-Ray versions?
      3ds Max 2015 Ext 1
      V-Ray EDU 3.10.02
      In 3DS Max 2014 + v-ray 3.xx I had the same problem lasts months...
      @artefaktos3d
        Hm ok. If you look at the V-Ray log file right after you get this issue, does it say anything useful?
          No Vlado, nothing rare in the log file... Now I test again and again the button, and now works, but in a moment the button disconects from the vfb...
          I send you the log file in a PM.
          @artefaktos3d
            Hi Vlado,
            Today I see the problem. The button isn't work if I change the Image Sampler.
            If I open a Scene and I don't change the Img Sampler, works everytime. When I change the Img Sampler (from Progressive to Adaptive, or Adaptive to Adaptive Subdvs), in fact... every combination disable my "Render Last" button.
            @artefaktos3d
              I've just run a quick test but I couldn't reproduce the issue.
              Is the issue scene dependent? Have you tried to reproduce is on a new empty scene?
              Can you capture this issue on video and send for investigation?
                I try to reproduce the problem today and capture it.
                @artefaktos3d
