Animation with moving objects
  • Animation with moving objects
    Hi
    I went through this tutorial and it worked fine with a small scene, but when I tried a slightly larger and longer scene,
    the rendered only black images. Each image took a second to render, and the preecalculated irr map looked fine
    during rendering the irr maps.
    Why does it render black?
    http://help.chaosgroup.com/vray/help...ials_anim2.htm
    Sounds like you might have accidentally left on "Don´t render final image" in the global tab.
      If it worked on a small scene and then when you tried once on a larger scene, 1st guess is you missed a step?
      It can however be something in your scene, maybe a plugin or something. Redo all steps on lets say a 10 frame sequence and see what you get?
      Kind Regards,
      Morne
        Ehe..... embarrassing "Don´t render final image" in the global tab...
          Yeah, I really wish I had more scripting skills, so I could script myself a prerender script to check for all those little things you can miss when submitting a job to the farm...
            You mean something like this?
            I just posted it under the "General" section...
            Kind Regards,
            Morne
