Motion blur is not applied to bifrost Mesh from Maya Alembic.
  • Motion blur is not applied to bifrost Mesh from Maya Alembic.
    Alembic is loaded through VRayProxyObject.
    How to use "bifrostVelocity"ColorSet of alembic as Velocity information by V-Ray 3dsMax?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Are you rendering in Max or in Maya?
      rendering is Max.
      (Maya alembic to Max VRayProxy)
      tested by 3dsMax 2015 and V-Ray 3.10.03.
      oakcorp.net
      v-ray.jp
        Is there anyone who loaded the bifrost Mesh of Maya into 3dsMax and has applied V-Ray motion blur?
        oakcorp.net
        v-ray.jp
          No. It will not work with the build that you have - we need to modify V-Ray slightly. Or, you can ask Autodesk to follow the Alembic standard and put the velocity where it should be.
            Ok.
            It reports also to the Autodesk side.
            And it is hopeful of the support by Nightlies by the V-Ray side.
            oakcorp.net
            v-ray.jp
