Problem saving in hdri
  • Problem saving in hdri
    Hello, I had some problems when I saved the file in the .hdri
    The image in Photoshop and VFB are not equal
    if I saved in .tga or ohter format ,the image it's correct
    thanks for help
    sorry for my simple language
    I use this setting
    AA Adaptive \ D.S.Subdivis : 64
    Max Ray Intensity: 20
    GI : Irr(DE)+AO +LC
    I used "Separate render channel" in the Frame Buffer to save the image
    thanks for help
    I use this setting
    GI : Irr(DE)+AO +LC
    [ATTACH=CONFIG]22588[/ATTACH][ATTACH=CONFIG]22588[/ATTACH]
    You've posted the same attachment twice. Is the difference that you have fireflies in the right image?
    A.
    www.digitaltwins.be
      Sorry, I corrected the post.
      my problem is: in the image in photoshop (right) there are some fireflies , but in VFB the image is correct.
      I have had this problem in several files, all saved in hdri
      thanks for help
        It seems like Gamma issue where both software are showing the image with different exposure.
        I suppose that PS should ask you whether you want it to represent the HDRI in sRGB gamma or not. Which one did you choose? Also what were the color mapping settings that you used when rendering the image?
        Furthermore do you get the same effect if you enable the sRGB option in the VFB widow? http://i.imgur.com/JTJLaea.png
        Also can you attach an .vrimg from the VFB?
