Bug: "Error: This irradiance map cannot be used in animation mode"
  • Bug: "Error: This irradiance map cannot be used in animation mode"
    Reproducible on this end using Vray 3.10.03
    Set the 3dsmax frames to a negative number (say -10) when generating and it will produce the error "Error: This irradiance map cannot be used in animation mode" when you set it to "animation - rendering" mode.
    Tried to use it on a simple animation that was done a while ago and it wouldn't work if I went into negative frames (-10 to 110). Re-generated with 0-110 and it was fine tho choppy for the first few frames.
    Hello,
    We just tested this on simple scene with animated ball from frame -10 and it works fine. Can you send us your scene on support@chaosgroup.com?
    Tsvetan Geshev
    Chaos Group
      I went to recreate it and.. it worked. I'm at a loss... apologies.
        Thank you for the feedback.
        Tsvetan Geshev
        Chaos Group
