vray instancer and DR
  • vray instancer and DR
    Hello,
    i got a simple scene, one object with a simple particle object, and vrayinstancer
    when turning off DR, it renders fine
    when turning on DR, the material is not rendered on the instanced particle objects (it just renders black)
    DR has "transfer misssing assets" on. The material is a simple material, without bitmaps
    https://dl.dropboxusercontent.com/u/...1/ger_rose.zip
    Any ideas ?
    ps: vray 3.10.03 max2015
    Thanks for the scene, will look into it.
      actually, i think it works, but not when the particle object is in isolation mode... or something like that
        The problem is that you are rendering with DR and no lights in the scene. Either create some lights or turn the GI on (you have background color different from black in the scene).
        When rendering with DR, max's default lights are not working, so always add some lights or GI (with environment lighting).
        Peter Matanov
        Chaos
