Unknown problem
  • Unknown problem
    Hi all, may i know what is this happen?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    Anything weird going on in your environment/effects tab? hotkey 8 Maybe exposure control is on for MR or something weird?
    Seems related to a camera. Try deleting and making a new one?
      Hi Deflaminis, thank you for your reply, i have check and nothing is on in environment/effect, but i am rendering the file with backburner.
      This only happen to all the slave when render with DR.
      Anyway, i will check back the file see whether is there any problem with the camera.
      Jackie Teh
        Does it appear if you render it locally with/without DR?
          Hi svetlozar.draganov, this message didn't appear if render using local pc without slave, it appeared in slave machine only.
          Did i do anything wrong?
          Jackie Teh
            Is there any hardware difference between the workstation and slave machines, especially in the amount of installed RAM?
            What is the exact version/service pack of V-Ray/3DSMax and OS?
            Is the issue scene dependent, does it occur on every scene or just on particular ones?
