black outline on alpha
  • black outline on alpha
    I'm not sure what I am doing wrong. Normally I can render out an object to be comped without any outline but with this scene I cannot. I have a helicopter rendered on a black background. The lighting etc is all in the env override.
    I'm using motion blur on just the blades. There is a dark outline around the body of the heli - as shown below
    The background is totally black. I am saving out to EXR with alpha.
    Regards
    Steve
    My Portfolio
    did you also add the lighting in the reflection/refraction env override?
    Kind Regards,
    Morne
      Yep. All 3 have the same vray sun map.
      Regards
      Steve
      My Portfolio
        Is this for a still or animation? Are you comping with PhotoChop or Nuke?
        Maybe pre-multiplied issue?
        Kind Regards,
        Morne
          I'm comping with aftereffects. It's an animation. I've done this method before and not had this problem so it's confusing me completely ! I thought you only had to render to a black background with the lighting in the env slots as we've discussed and then output to an 32bit EXR with alpha. I was using straight comp method in aftereffects but it lost detail in the motion blur parts of the helicopter rotors. If I premult the image I have to make the matt colour a light gray to reduce the edging but I'm pretty sure this isn't a correct comp with perfect alpha.
          Regards
          Steve
          My Portfolio
            it happens when you multiply elements over each other, you need to unpremultiply everything by the alpha, do your comp then premultiply it again.
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
