I'm having major problems with matching motion blur from a rendered comp with motion blur at render time with a background with velocity pass using RSMB.
If you check out the attached image you will see that the motion blur at render time (the helicopters) does not match the velocity vector render blur using RSMB in aftereffects.
Also if you check out the 2nd image with the blacked out half section you will see I have another problem when using motion vectors when close up to an phoenixocean plane.
