3dsMax crashes with DR
  • 3dsMax crashes with DR
    Hey,
    3dsMax constantly crashes when DR is enabled. It happens everytime I hit render. Here are the Log messages:
    [2015/Mar/19|14:53:17] ================================================== ==========
    [2015/Mar/19|14:53:17] Console created, V-Ray A for x64 from Dec 13 2014, 21:13:56
    [2015/Mar/19|14:53:17] Compiled with Intel C++ compiler, version 14
    [2015/Mar/19|14:53:17] Host is 3dsmax, version 17
    [2015/Mar/19|14:53:17] V-Ray DLL version is 3.10.02
    [2015/Mar/19|14:53:21] [VRender] Constructor entered.
    [2015/Mar/19|14:53:21] Setting default filter kernel.
    [2015/Mar/19|14:53:21] "default" preset not loaded: [loadPreset] Cannot open file "C:\Users\Oliver_3D\AppData\Local\Autodesk\3dsMaxD esign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg"
    [2015/Mar/19|14:53:21] [VRender] Constructor done.
    [2015/Mar/19|14:53:22] Resetting VRender.
    [2015/Mar/19|14:53:22] Setting default filter kernel.
    [2015/Mar/19|14:53:22] "default" preset not loaded: [loadPreset] Cannot open file "C:\Users\Oliver_3D\AppData\Local\Autodesk\3dsMaxD esign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg"
    [2015/Mar/19|14:53:22] [VRender] Constructor entered (loading from file).
    [2015/Mar/19|14:53:22] [VRender] Constructor done.
    [2015/Mar/19|14:53:22] Loading from file.
    [2015/Mar/19|14:53:22] Loading filter parameters.
    [2015/Mar/19|14:53:22] Loading done.
    [2015/Mar/19|14:53:22] VRenderer destructor entered.
    [2015/Mar/19|14:53:22] VRenderer destructor done.
    [2015/Mar/19|14:53:26] Resetting VRender.
    [2015/Mar/19|14:53:26] Setting default filter kernel.
    [2015/Mar/19|14:53:26] "default" preset not loaded: [loadPreset] Cannot open file "C:\Users\Oliver_3D\AppData\Local\Autodesk\3dsMaxD esign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg"
    [2015/Mar/19|14:53:52] [VRender] Constructor entered (loading from file).
    [2015/Mar/19|14:53:52] Setting default filter kernel.
    [2015/Mar/19|14:53:52] "default" preset not loaded: [loadPreset] Cannot open file "C:\Users\Oliver_3D\AppData\Local\Autodesk\3dsMaxD esign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg"
    [2015/Mar/19|14:53:52] [VRender] Constructor done.
    [2015/Mar/19|14:53:52] Loading from file.
    [2015/Mar/19|14:53:52] Loading filter parameters.
    [2015/Mar/19|14:53:52] Reading host list from scene
    [2015/Mar/19|14:53:52] Adding host "RF-01":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-02":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-03":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-04":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-05":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-06":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-07":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-08":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-09":20204 from scene
    [2015/Mar/19|14:53:52] Adding host "RF-10":20204 from scene
    [2015/Mar/19|14:53:52] Loading done.
    [2015/Mar/19|14:53:52] [VRender] Constructor entered.
    [2015/Mar/19|14:53:52] VRenderer destructor entered.
    [2015/Mar/19|14:53:52] VRenderer destructor done.
    [2015/Mar/19|14:54:30] Cloning VRender.
    [2015/Mar/19|14:54:30] [VRender] Constructor entered.
    [2015/Mar/19|14:54:30] Setting default filter kernel.
    [2015/Mar/19|14:54:30] "default" preset not loaded: [loadPreset] Cannot open file "C:\Users\Oliver_3D\AppData\Local\Autodesk\3dsMaxD esign\2015 - 64bit\ENU\en-US\plugcfg\vray.cfg"
    [2015/Mar/19|14:54:30] [VRender] Constructor done.
    Is this for any scene? Does it crash if you just leave the local machine to render without any DR slaves?
      Hey Vlado,
      no, this happens with a single file only. When DR is disabled, the scene renders fine. I am investigating now, it seems that a specific DR node is the culprit. We have 10 nodes, so far it renders fine with the first 5 of them.
        The problem was solved. It was a corrupt plugin file on one of the nodes. Sorry for the inconvenience.
