the intensity mask seems to work if you have the image clamped or perhaps it is sub pixel mapping or perhaps it is the type of color mapping i am using on this job.
vray lens flares problem
Tested on another scene, bloom and glare work with DR. But only bloom works with backburner (and no DR).
A black glare mask file is actually saved out too.WerT
www.dvstudios.com.au
Okay finally tried the work around and it did not fix it - the slave on backburner still only rendered out the bloom not the glare.WerT
Let me chime in on this one. The intensity parameter for the masks don't do anything.
When I enable the intensity, the glare and bloom is gone. The corresponding render elements are blank.
http://forums.chaosgroup.com/showthr...arameters-work
I get that with some scenes kosso and not with others. I think it might have to do with the color mapping you've chosen. Seems to work with linear multiply.
As a work around I am currently rendering with multiple copies of max open but not using the 'local host' in the DR settings. thus the image comes back to the main machine and gets applied correctly.
Need a lot of ram to do this of course the open scenes use full ram.Last edited by werticus; 02-04-2015, 09:28 PM.WerT
Interesting.. Attempting to render an animation via BB with a baked IR and LC map. Some of the frames have gloom and some have glare too. And the first 3 frames have neither.WerT
Originally posted by werticus View PostInteresting.. Attempting to render an animation via BB with a baked IR and LC map. Some of the frames have gloom and some have glare too. And the first 3 frames have neither.
thanks! would it be included on the nightlies?Surrealismo
https://www.facebook.com/surrrealismo
Originally posted by leo.surrealismo View Postthanks! would it be included on the nightlies?
