Saved DR to max file but doesn't load when render.
  • Saved DR to max file but doesn't load when render.
    Hi guys,
    I'm sending jobs to BB with DR enable and the ips of the nodes are saved with the max file.
    Till now I never had any issues with that, but resently this seems to be broken, this is what I'm got in to the Vray message :
    On some of the nodes, if I try to locate the "vray_dr.cfg" there is even any Autodesk folder in AppData\Local.
    On the nodes that does have the full path with the "vray_dr.cfg" file, the node uses what's inside that file and not what's saved with the maxfile.
    Any thought why this seems to be broken?
    Stan
    3LP Team
    Would you please give us a step by step instructions how do you submit the job to BackBurner.
    The attached log file doesn't seem to be from BackBurner job. V-Ray messages window is present when rendering via 3DSMax GUI.
    What are the exact BackBurner and 3DSMax versions that you are using?
    Please make sure also that "Save Server In The Scene" option is activated and there are added and enabled servers in the DR-list:
