Alembic cache rendered as black box and crashes 3ds max using all available RAM
  • Alembic cache rendered as black box and crashes 3ds max using all available RAM
    Hi
    I simulated sand in Houdini and then export as alembic cache. (as usual)
    Then I imported abc as vrayproxy and hit render.
    First 35 frames rendered perfect (fast and with small use of RAM, as usual). On frame 36 I see black box (when rendering) and 3ds max start using (very fast) all my RAM (32 GB). Then crashes.
    After 37 frame I didn't see anything, only huge use of RAM and then crash.
    I tried re-simulate this file many times and result every time the same.
    Please, help me! Why this happens?
    My abc-file - http://feedback.3dyuriki.com/abc/wormsand8.rar
    P.S. V-Ray 3.1, 3ds max 2014 SP5.
    You can find me here:
    3dyuriki.com
    Linkedin.com/in/3dyuriki
    vimeo.com/3dyuriki
    plus.google.com/3dyuriki
    Thank you for attaching the alembic file for this issue.
    The error is reproduced here as well : "Invalid geometry normal " and the whole frame is empty. We are investigating now.
    Tashko Zashev | chaos.com
      I found what cause problem.
      When I simulate sand in Houdini, sand fall "under ground" (in direction to negative Y-axis). So particles of sand have huge minus by Y coordinate.
      When I lift sand more above "ground" problem gone.
      Why vraypoxy don't understand particles with -Y coordinate?
      3dyuriki.com
      vimeo.com/3dyuriki
        the problem is that after frame 36 in your particle positions appear some broken floats (1.#QNAN). From tomorrow's nightly we drop such particles, so you will be able to render your alembic.
        Asen
          Oh, thank you!
          And where I will find this update?
          3dyuriki.com
          vimeo.com/3dyuriki
            You can email support@chaosgroup.com and ask for access to the nightly builds - explain that you have a problem that is fixed there.
