Slave problem
  • Slave problem
    Hi all, one of my slave have this message show up, may i know what problem with my slave?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    I got the vraylog file, where should i send please?
    Jackie Teh
      Do you have any raytrace materials in your scene?
      You can run the "vraysceneconvert" to see if that fixes the issue.
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
        hi jacksc02, i have read the vraylog file with notepad, it show below:
        Preparing objects
        [2015/A/20|12:12:56] Updating object L
        [2015/A/20|12:12:56] Validity for node "Layer:1046" is [forever], node handle is 12316
        [2015/A/20|12:12:56] Validity for node "Layer:1051" is [forever], node handle is 12315
        [2015/A/20|12:12:56] Validity for node "Layer:1050" is [forever], node handle is 12314
        [2015/A/20|12:12:56] Validity for node "Layer:1049" is [forever], node handle is 12313
        [2015/A/20|12:12:56] Validity for node "Layer:1048" is [forever], node handle is 12312
        [2015/A/20|12:12:56] Validity for node "Layer:1041" is [forever], node handle is 12311
        [2015/A/20|12:12:56] Resetting VRender.
        [2015/A/20|12:12:56] Validity for node "Layer:1040" is [forever], node handle is 12309
        [2015/A/20|12:12:56] Setting default filter kernel.
        [2015/A/20|12:12:56] Validity for node "Layer:1045" is [forever], node handle is 12307
        [2015/A/20|12:12:56] error: UNHANDLED EXCEPTION: Preparing objects
        Last marker is at ./src/vrayrenderer.cpp, line 2398: Preparing camera sampler
        so i guess it is the object start with name Layerxxx, i examine all object in the scene with that start name,i have attached vray material to this object, anyway this object are model provided by my client, dont know what software they are using to create their models.
        Jackie Teh
          [ATTACH=CONFIG]23834[/ATTACH]
          Does the error appear only on that particular slave?
          What is your render setup - local, network via V-Ray DR, network via Render manager?
          Does this slave differs from another ones in terms of software/hardware?
          What is the V-Ray version that is installed on that slave?
            It happen on all slave, but not in local workstation.
            I was using DR when this happen. my company have 4 local workstation sharing 4 slaves, i am not sure is this can cause this problem?
            all the slaves are having same hardware and software, and it set up in the same day.
            V-Ray 2.40.04
            Jackie Teh
              Does the crash occur with every scene or with just that particular one?
              If it is scene dependent we will need the scene for investigation in order to provide further assistance.
