glass material with 2 different materials either side issues
  • glass material with 2 different materials either side issues
    If I setup a basic glass material and apply it to an object it works fine. If I apply the 2 different vray glass materials to either side the box (the glass panel) where one material has a texture in the glossiness to give a frosted glass look in a particular place, the refraction for the entire panel looks wrong.
    Regards
    Steve
    My Portfolio
    It needs to be the same material, however use can use the VRayMultiSubTex texture in conjunction with a VRayColor map to give it different properties on different sides.
      Thanks. Could I also separate the opposite face meshes and apply different materials to it ?
      Regards
      Steve
      My Portfolio
        It has to be the same material, otherwise V-Ray can't compute the IOR properly. They can be separate meshes though.
          ok. Thanks for clearing that up.
          Regards
          Steve
          My Portfolio
