I'm having problems with the Progressive sampler. If I use it, turning off Affect background in Color Mapping doesn't work. It renders as if I've turned it on. I'm using Vray 3.10.03 with Max 2016. Can anyone else confirm this issue? According to the following video, it should be compatible with all the features of the production renderer.
Affect background doesn't work with Progressive sampler
Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2Tags: None
Thanks for the help, didn't know that. I will use the Adaptive sampler in this case then.
By the way, If I may make a suggestion. I think it would be good this limitation to be documented in the online help as a note at the bottom of this page. At first I thought I was doing something wrong since I didn't see this mentioned there.
Thanks again for the help!Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
Wow, that was fast! Thanks again, you guys are great.Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
