OSL Texture Blue
  • OSL Texture Blue
    Hi All,
    It seems that texture blurring isn't working for OSL textures. See the following example:
    Code:
    shader blurtest01
           string test_bitmap = "",
           float blur_val = 0.0,
           output color Col_Out = color(0.5)
        color cColor = texture (test_bitmap, u, v, "blur", blur_val);
        Col_Out = cColor;
    Is there another parameter that I'd need for it to work?
    Thanks!
    Rens
    Rens Heeren
    Generalist
    WEBSITE - IMDB - LINKEDIN - OSL SHADERS
    I believe in 3ds Max this is controlled by the texture's own blur parameters.
      Ok, thanks!
      Rens Heeren
      Generalist
        Unfortunately the only keyword argument we support for the texture built-in function is "alpha".
        You could try and use the "Coordinates" section of the OSL texture/material plug-in and/or the Bitmap one's.
