Hello,
I thought i would give the forum a try and see if i can get this fixed today. So i am getting max set up for DR rendering I already have maya going for this with no issues, but need to do a collaboration from max. I did all the Back Burner stuff just fine had a little issue with the ports but those are opened as well now.Everything seems to be correct I have no errors and the dr host is connected but when DR is on my VRAY frame buffer renders complete black now this is odd because if I set a pass say the MATID it shows the pass but never the final pass. I should say if I turn DR off the image shows just fine in the buffer.
I am using max 2015 and vray 3.10.3 of course same set up on both machines same prefs on both machines.
I hope someone has some ideas other wise wait for tech to answer
