The meddlesome feature of a new Chaos installer
  • The meddlesome feature of a new Chaos installer
    When vrlclient.xml is other than localhost/127.0.0.1, even though having selected WorkStation by install type, a license server is not installed by a default.
    Please change this meddlesome behavior!
    Almost all users install software by initial setting. They do not customize.
    There is also a case where localhost is set by the host name or an IP address.
    Regardless of a setup of vrlclient.xml, a license server should be installed by a default the case where WorkStation is selected.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    For the record, I do customize, and I prefer the installer to behave as is.
    If you need to create many identical installations, why not use an XML configuration file as shown here?
      I think we always install the license server executable when "workstation" mode is selected, but let me double-check.
