Returned an invalid bump normals
  • Returned an invalid bump normals
    Okay, not a V-Ray issue, or at least I don't think. I ended up buying Evermotion 154, which are tropical trees. Now, I am getting around 2000 'returned an invalid bump normal' errors. Should they be ignored, or do they need to be addressed? If they need to be addressed, what's the issue?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Here, is one of the culprits. It seems that it's from my Evermotion 85 libraries.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Do the objects have proper UV coordinates?
        Do the objects have proper UV coordinates? Best regards, Vlado
        gosh, I don't know. I guess I buy these things assuming they'll work. I'll look deeper when the render is done.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          With all these warnings, it might take a while though...
            With all these warnings, it might take a while though... Best regards, Vlado
            2500 warnings...ugh!
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              The tree tree looks fine. It has been collapsed, so I don't see the UVW Mapping mod.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                You can look at the UVW channels with a UVW unwrap modifier. If you like, you can also send me the tree along with the normal map to vlado@chaosgroup.com and I will take a look at what's wrong.
                  For now, I turned off bump using VMC. The trees are not close, so hopefully it'll not matter for this scene. When I get a change I'll email you a tree.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Ok, thanks!
                      I was getting this with the HD Palms pack. Turns out they were overriding all the normal map gammas to 2.2 (I can't imagine why), and changing them back to 1.0 fixed it.
                        I've had issues with those trees before. Swapping out the the vanilla bump/normal node for a vray one remedied the situation. Was getting bucket mismatches.
                        Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
                        Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
                          You would think that they would have better quality control. I mean, don't they test the?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Bobby,
                            I have a script that will replace max normal bumps with vray ones.
                            PM me if you want it.
                            Chris Jackson
                            Shiftmedia
                            www.shiftmedia.sydney
                            • #15
                              Script worked beautifully, thanks!
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
