3.20.02 Cant connect slaves after the last render
  • 3.20.02 Cant connect slaves after the last render
    Hi vlado... need advice.
    All the nodes cant connect after finisht the job. The only solution is restart, mannualy, all the spawners.
    max 2016
    windows 8.1 64 wostation
    Slave: windows 7
    Try the "restart slaves on render end" option?
      hil Vlado!!!
      Yes...
      Al the usual settings for DR jobs are enable.
      Save Save scene
      Restar salve
      transfer assets
      etc..
      All the spawners are from 2016 and 3.20.02. The Previus Spawenrs (2014 and previous) has been deleted.
        ive just started having th same problem on one renderbox. one starts again as normal, but the other needs a manual restart. strangely it was working this morning.
          Does it happen on every scene?
          What happens if you render a relatively simple one with a few basic primitives and a light?
            With any scene.
            I will try that
              i just had a deadline, good timing with this issue.
                Can you also show me the V-Ray log file from one of the render servers once it refuses to render?
                  [2015/Jan/27|17:33:57] warning: Failed to delete server scene file "C:\Users\monkey\AppData\Local\Autodesk\3dsMax\201 4 - 64bit\ENU\temp\vray_server_scene.max" (183)
                  is the last entry in the log file on my problem machine. a permissions issue? strange its just started happening, ive been using this renderbox for ages with no issue.
                  do you want the rest of the log? nothing else there looks out of the ordinary to me.
                    Is it possible that you have two V-Ray spawners running?
                      nope, i have the service there, but its stopped.
                        In my case its the same thing.
                        Console created, V-Ray A from Jan 8 2015, 13:43:24
                        [2015/Jan/11|01:48:08] Scene loaded from "C:\Users\granja1\AppData\Local\Autodesk\3dsMaxDes ign\2015 - 64bit\ENU\temp\vray_server_scene.max"
                        [2015/Jan/11|01:48:08] [DR] getting sequence data...
                        [2015/Jan/11|01:48:08] [DR] sequence data is NULL, aborting
                        [2015/Jan/11|01:48:08] Closing DR session from 192.168.1.200
                        [2015/Jan/11|01:48:08] warning: Failed to delete server scene file "C:\Users\granja1\AppData\Local\Autodesk\3dsMaxDes ign\2015 - 64bit\ENU\temp\vray_server_scene.max" (183)
                          The problem is... it doesnt exist. (3dsMaxDes ign\2015 - 64bit)
                            This is a build of V-Ray 3.10 on the slave (the date at the start of the log is Jan 8th); make sure both the client and the server run the same V-Ray versions.
                            • #15
                              i will check that
