Foresr Pro V-Ray Override Material
  • Foresr Pro V-Ray Override Material
    My grass is making my white soffit green, so I put a V-Ray Override Material with a Vray gray material for the GI. I render, the green reflection is still there and when I go back to the material, the override material is gone.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I had to go into each sub-material, however when I went to add the GI material, each one took about 2 minutes to apply.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      An old trick I used to do for just that problem is select the grass, right click and select the V-Ray object properties and turn down the "generate GI" at least by half and that usually did the trick.
      Cheers,
      -dave
      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
        Good! I'll try that next time. Thanks!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
