Render Setup dialog opens progressively slower and then crashes Max
  • Render Setup dialog opens progressively slower and then crashes Max
    I'm experiencing a very strange problem with Vray since I installed version 3.20. Each time I open and close the Render Setup dialog, it opens progressively slower and eventually Max crashes. The first few times it opens in 1 sec. But after you work on a scene for a longer period and you have opened the dialog many times, it starts to open after 3-4 seconds. It even managed to crash my scene.
    Try this: Open a new instance of Max and switch to Vray renderer. Then start hitting F10 repeatedly in order to open and close the Render Setup dialog. I managed to crash Max after the 48th time I opened the dialog. By the way, is it me or the render setup dialog opens a lot slower in general even after the first opening compared to Vray 3.00?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Which Max version?
      Max 2016 on Win7 SP1 x64. System specs: i7 4930k, 32GB RAM, GTX980, SSD.
      Aleksandar Mitov
      96GB DDR5
        I think it may be a bug in 3ds Max 2016. Does it happen with f.e. mental ray or the scanline renderer?
          No, doesn't happen with Mental Ray or Scanline, I've just tested it.
          Aleksandar Mitov
          96GB DDR5
            Ok then - thanks for the confirmation. Will look into it.
