Different buckets produce different results with Vray Fur
  • Different buckets produce different results with Vray Fur
    I'm having problems with Vray Fur. Different buckets produce different results. Please take a look at the attached image. This is rendered on a single PC, no DR or Backburner is used. Vray version is 3.20 on Max 2016.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Not sure what's going on right away; can you get me a scene for this to vlado@chaosgroup.com (you can probably just remove everything bug the grass).
      I just emailed you the scene. Hopefully we can track this down.
      Aleksandar Mitov
      96GB DDR5
        Hello,
        can you send us the original scene, because we cannot reproduce the problem with the current one.
        P. Getov
        Peter Getov
        V-Ray developer
          Ok, I will send the completely untouched original scene shortly. The one I sent earlier had the unnecessary objects removed.
          Aleksandar Mitov
          96GB DDR5
            I managed to reproduce the problem with the original scene.
            We are looking forward to fix it.
            Peter Getov
            V-Ray developer
              Great, thanks for the quick reaction, Peter.
              Aleksandar Mitov
              96GB DDR5
                Hello,
                the bug is fixed and the changes will apply in the next patch.
                If you have access to the nightlies you can try it with tomorrow's new build.
                If you don't have access to the nightlies and you need the changes sooner, talk to Vlado.
                P. Getov
                Peter Getov
                V-Ray developer
                  Thanks, Peter!
                  Aleksandar Mitov
                  96GB DDR5
