Still suffering from this vexing problem here................ & often its time consuming trying to select all the vray proxies to either individually sort out their display or to run that script.
Proxys not displaying when re-opening a scene
Originally posted by leotchest View PostStill suffering from this vexing problem here................ & often its time consuming trying to select all the vray proxies to either individually sort out their display or to run that script.
Or any of the scripts on script spot like this one (not sure this one works): http://www.scriptspot.com/3ds-max/sc...ay-proxy-tools
Is there any update for this issue? I cannot submit my current project to the renderfarm and rendering locally is not an option. All proxies render as boxes when I first open the scene, or when I submit to the farm.
Any updates or ideas are greatly appreciated.
Have you tried to use the script mentioned earlier, does it help when rendering on a local machine? Also do you get any errors in the log files after rendering your scenes?
Thank you for the reply. No, it really isn't an error per se. I would call it a "refresh on startup issue". When I open the scene, I get a bounding box representing my proxy, even though the path is correct. To fix this, I select the box and, in the modifier rollout, refresh the path. Then, it will preview and render properly. That is why it won't work on the renderfarm. The farm opens the scene and renders the box since the path is not "refreshed" on file open.
Just to be clear, locally, I have no problem. The renderfarm is the main issue. I simply can't render locally and make the deadline. I must use the renderfarm (in 2 weeks). Is there a way to "embed" the script in the scene, like in maya? Force a refresh on file/open?Last edited by zacktown; 15-03-2016, 02:32 AM.
As I wrote in your other post it will be best to send us a scene so we could investigate further. You can send it to support@chaosgroup.com . Please make sure to mention this thread.
Hi
We have been having a similar issue but the problem got much more serious just at the moment we started submitting the job to our renderfarm, as usual we have an extremely tight deadline and cant render our proxy heavy scenes!
Please do let us know if any solution is out there....
Thanks!
As it turned out, my issue was intermittent and I haven't had it in the past 3 weeks, so my investigation into it ceased. One suggestion that I haven't had a chance to try was to import the problem scene into an empty max scene. Might work? I hope so.
We found a temporary solution for it still not tested fully but here it goes,
load up the problematic file, then run the below line at script listener
callbacks.addScript #filePostOpen "for i in $VRayProxy* do i.display = 3" id:#ozPD persistent:true
this will add a callback function to that particular file and each time file gets loaded it will run the display script, hopefully same would also work on render farm
I do hope this problem gets sorted out properly soon, looks like most of our files are getting affected by it.
Hello guys,
Since for some reason we are not able to find the scene with the proxies that renders as boxes would it be possible to send the scene again to support@chaosgroup.com?
A ticket number from the communication would be also very helpful.
Thank you very much in advance.
We are working very hard trying to resolve all the issues but sometime more time is needed for particular issue or there are more important issues to fix.
Would you please remind us what are the issue that you are waiting to be resolved, we might consider to raise their priority and fix them in a short time.
...checkout if you have only the name of the proxy, without the .vrmesh ending.
i have an old file with this problem at the moment and i had a second look, and that was the problem here.
if i called the path, vray found the right one itself and remapped it with the ending...and the proxy was shown.
hope this helps someone
